Hi all,
I am trying to get view from level selected but not able to find the result. we have a node called hasview from rhythm and it is giving me true but I want to get the view from the level selected.
Please let me know how to get it ? Please find the below snip for the reference.
Can you be a little more specific what you wanna achieve as a Level can have multiple Views associated with it.
That being said ;).
hello, have you searched the side of the view settings? Element.Parameters
Cordially
christian.stan
Hi @bvs1982 I want to get the views associated with that level. I checked this node Level.Views from clockwork but it is not showing me. Can you please tell me which version of clockwork are you using ?
I am using the version as below snipped
It works for me. Clockwork 2.3.0 and Revit 2021.
should be in clockworks version 2.4.0 as well
can you please check @sovitek as I am not finding that node in 2.4.
Yes Shashank…i find it here
I found it thanks but can you check whether you’re also getting the same as snipped below ? @sovitek
seem to work here , try a reinstall could probably help…not sure
I tried to dig into the idea mentioned above
here is
14 juillet forum anglais.dyn (21.9 KB)
Cordially
christian.stan
Yes Christian…thats basically what clockwork node does
great one
@christian.stan thank you so much. It worked for me and I really appreciate for this.
