Get “Type Mark” parameter value from structural columns in linked file?
Hi everyone,
How can I extract “Type Mark” parameter value for structural columns in linked file? I find some solutions in the forum with streamnodes or bimorphes packages but I’m finding some problems with latest version of dynamo. Can you help me?
Thanks and regards.
Hello…you could try something…
Yes, I tried something like that but this is the result:
The case that is more near to solution that i search is in image below, but in this case parameter value returns null value.
In your first image, how many link instance do you feed in ? get the link instance with “get at index”
Yes, It works in this way. Perfect.
But instead to select one link at time or with a series of index to put, in your opinion can i select link by workset value for example?
not sure i understand, but you can get the workset from your linked element
