I want to use the dynamo node to get the direction of the two cable-trays.
But I have no idea how to do
Can you post what you tried ?
One of the main goals of the Dynamo community is to help others. One way to do that is by answering your questions. But to get the right answer, you’ll first have to ask your question in the right way. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions on how to achieve that. Do not think of these suggestions as rules and especially do not take them as a guarantee of getting an an…
Many things are possible but your description is not precise enough.
Do you want the vector, to know if the cable Trays are vertical ?
GPbim
December 11, 2020, 5:48am
3
Hi @Alban_de_Chasteigner ,
I was able to filter now the vertical and horizontal cable tray. My issue is that when I try to create curve along the direction of the cable tray it will not follow.
Filter Vertical and Horizontal elements.dyf (17.0 KB)
Filter Vertical and Horizontal Pipes.dyn (18.6 KB)
