Get Text From Multiple Multileaders
Hi All,
I’m trying to get the text content from multiple multileaders in the same drawing. I’ve seen the thread below
I’ve tried using
OUT = IN[0].InternalDBObject.MText.Text
which works when selecting a single multileader but I need a fix for feeding multiple objects into the input.
Try this:
OUT = [ i.InternalDBObject.MText.Text for i in IN[0] ]
Note that this will now fail if you pass a single item in instead of a list. For both you’d need to expand the code to ensure the data received from the Dynamo environment is a list.
Thanks @jacob.small , worked like a charm!
