I am working on dynamo script to create Revit model from CAD drawing.
To this respect I need to sort all text data x and y value.
But I have a problem for Sort and group node Could you please help me for this problem because I will manipulate my beam size from this Cad text.
Could you please help me ?
First of all thank for this solution but I have a new issue this code.
Have u any think about this issue.
It seems that you forgot a closing square bracket after x[1].Y at the end in the line 10.
I also found a mistype, you should have typed âpointsâ and not âpointâ as you did in the line 10.
I have closed it but I have new issue about code
It is : Warning: Your inputs lie outside of the allowable modeling range, consider choosing the Large setting with a modeling range between 0.01 and 1,000,000 from the âSettings => Geometry Working Rangeâ dialog
IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File ââ, line 11, in
File ââ, line 11, in <lambda$45>
AttributeError: âlistâ object has no attribute âXâ
It seems that the block âPoint.ByCoordinatesâ returns a nested list. This is the reason why it doesnât work. You can use the node âList.Flattenâ after the block.
