Years later needed this! Here is the py code condensed:
import clr ## Load the Python Standard and DesignScript Libraries
doc = DocumentManager.Instance.CurrentDBDocument ##Current DOC
tags = UnwrapElement(IN[0]) ##The inputs to this node will be stored as a list in the IN variables.
TaggedElements=[] ##Initialize the output list
TransactionManager.Instance.EnsureInTransaction(doc) ##Get transaction manager fo rundo
for i in tags: ##For each tag
tagID = doc.GetElement(i.Id) ##Get the ID
taggedID = doc.GetElement(tagID.TaggedLocalElementId) ##Get the id of the tagged element
TaggedElements.append(taggedID) ##Add it to the OUT list : )
TransactionManager.Instance.EnsureInTransaction(doc) ##End transaction if crash
OUT = TaggedElements ##Return tagged elements
