SeanP
November 30, 2018, 5:09pm
21
You do not have “taggedelementids” define in the script. “taggedelements = ” is defined.
clr.AddReference('RevitAPI')
dataEnteringNode = IN
tags = UnwrapElement(IN[0])
taggedelements = []
taggedelementids = []
for i in tags:
tagID = doc.GetElement(i.Id)
taggedRoom = tagID.Area
taggedElem = doc.GetElement(taggedRoom.Id)
taggedelements.append(taggedElem)
taggedelementids.append(taggedElem.Id)
OUT = taggedelements,taggedelementids
Hello Sean,
Thank you very much for your help!!!
vanman
April 4, 2019, 9:21pm
23
SeanP:
import clr clr.AddReference(‘ProtoGeometry’) from Autodesk.DesignScript.Geometry import * clr.AddReference(‘RevitServices’) import RevitServices from RevitServices.Persistence import DocumentManager from RevitServices.Transactions import TransactionManager clr.AddReference(‘RevitAPI’) import Autodesk from Autodesk.Revit.DB import * clr.AddReference(‘RevitNodes’) import Revit clr.ImportExtensions(Revit.Elements) clr.ImportExtensions(Revit.GeometryConversion) dataEnteringNode = IN tags = UnwrapElement(IN[0]) taggedelements = taggedelementids = doc = DocumentManager.Instance.CurrentDBDocument TransactionManager.Instance.EnsureInTransaction(doc) for i in tags: tagID = doc.GetElement(i.Id) taggedRoom = tagID.Area taggedElem = doc.GetElement(taggedRoom.Id) taggedelements.append(taggedElem) taggedelementids.append(taggedElem.Id) TransactionManager.Instance.EnsureInTransaction(doc) OUT = taggedelements,taggedelementids
Hi, I got this error. Dynamo 1.3.4 Revit 2019
SeanP
April 4, 2019, 9:35pm
24
Your code didn’t paste with the proper format into the python node.
Make sure everything under “for I in tags:” is tabbed once until you get to Transaction Manager.
vanman
April 4, 2019, 10:21pm
25
Thanks Sean! Would you be kind enough to modify to Get model element IDs? Or would it need to be specific to wall elements and floor and so on
Feel like I’m close
taggedelements = []
for i in tags:
taggedElem = doc.GetElement(tagID.TaggedLocalElementId)
SeanP
April 4, 2019, 11:07pm
26
I’ll take a look when I get back to a computer. May need to play with the tabbing of the last two lines be removing it.
vanman
April 5, 2019, 1:13am
27
so close! but not doing the whole list
SeanP
April 5, 2019, 1:29am
28
I am betting it had to do with how your making the lists for output. My guess is your only getting the last item because your over writing all the others. Make sure your using a list.Add(element) for the outputs and not just elemId=element.Id
I am also not sure, but looks like you have .append but it should be .Add I believe.
vanman
April 5, 2019, 1:39am
29
I will try figure out what your saying but this is where im at
taggedelements = []
for i in tags:
SeanP
April 5, 2019, 1:42am
30
My bad, but indent the last line and try .Add vs .append. Right now your only adding the last item to the final output list. That’s should do it.
vanman
April 5, 2019, 1:44am
31
Boom! your amazing. Thank you
taggedelements = []
for i in tags:
taggedelements.Add(taggedElem)
Years later needed this! Here is the py code condensed:
import clr ## Load the Python Standard and DesignScript Libraries
doc = DocumentManager.Instance.CurrentDBDocument ##Current DOC
tags = UnwrapElement(IN[0]) ##The inputs to this node will be stored as a list in the IN variables.
TaggedElements=[] ##Initialize the output list
TransactionManager.Instance.EnsureInTransaction(doc) ##Get transaction manager fo rundo
for i in tags: ##For each tag
tagID = doc.GetElement(i.Id) ##Get the ID
taggedID = doc.GetElement(tagID.TaggedLocalElementId) ##Get the id of the tagged element
TaggedElements.append(taggedID) ##Add it to the OUT list : )
TransactionManager.Instance.EnsureInTransaction(doc) ##End transaction if crash
OUT = TaggedElements ##Return tagged elements
This may be years later, but I just found this thread and it was extremely helpful. I just wanted to thank you for sharing your python code. It works great!
Hi, I’ve tried everything, even copied the code from above, still to no avail. This is what I have:
clr.AddReference(“RevitAPI”)
taggedelements =
for i in tags:
I get the following warning message:
IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File “”, line 31, in
AttributeError: ‘FamilyInstance’ object has no attribute ‘TaggedLocalElementId’
Just a guess- you may need to update your python (ala~ newer version of Revit)- and this code was written for Revit R22. If you are in 2019 that may be the issue.
Coming to an old post, but it seems an everlasting one!
I need this exact function, but script doesn’t work for me.
It could be newer dynamo/Revit?
I’m running Revit 2023, and Dynamo 2.16
This dynamo also prefers the newer CPython3
Can anyone help with this?
