I want to get the surfaces of a boundingbox parallel to current view (always 2)
The output from “vertical” gives me 4 surfaces, which two are parallel to my view?
thnx
Marcel
thnx
Marcel
Hi Marcel,
I guess you an check the orientation of your vertical surfaces by checking the normal vectors to each surface. I do not have much experience with manipulating views in Dynamo, but i guess you can one way or another extract sudo-“normal vector” and compare it with the ones of the surfaces.
