Hi everyone, how can I retrieve 4 bounding boxes out of 4 poly-surfaces that I highlighted and numbered in the image below?
I took the Bounding Boxes of the 3 small openings above, align their elevations with the giant opening below. Then convert them all to PolySurfaces and use node Surface.Difference to clash these PolySurfaces and get 4 un-obstructed portions (as numbered from 1 to 4). Now, how can I create 4 bounding boxes out of these 4 portions? Dynamo only recognizes these 4 as a single PolySurface and therefore only form 1 single BoundingBox out of them all.
Thank you very much for your insights! the boundingboxes are important as I will later convert them into line loads for my structural calculations.
