I’m trying to get a more efficient way to do my code. I would like to not repeat the same code 8 times!
My goal is to have the surface area of walls for all of my eight orientation (N, NE, E, SE, S, SW, W ,NW) per room as shown with the excel file. This is currently what i am exporting.
My code :
I have a list of surface orientation per room and a list of surface area per room. (1)
I get all the indices of my orientations. (2)
If the list is empty (3), i fill list with the exact amount of 0. (4)
If not empty i fill the list with the surface area of that orientation. (5)
I sum the areas per room per orientation (6).
Finaly i join my lists to later transpose.
Thank you
Consider something like this:
To each orientation sublist, add N/NE/E…NW. In the corresponding wall area list, add an equivalent amount of 0s. This step is to facilitate the export later (filling in all of the ‘zero’ entries)
You can now GroupByKey the wall areas, using the Orientation list as the keys. Then, math.sum the grouped sublists.
For each room, you should now have two lists: N/NE/E…BW, and a corresponding equal list of areas. You can sort the sublists so that the ordering is consistent for the export step.
It worked perfectly!
Thank you @Robert_Younger
Can you share your dyn. file if it’s possible? I’m tyring to calculate room surface area including walls, structural elements, floors etc. and your file can help me.
