Get sublist from a list
Hi, how could I get list A?
@Christhian What’s your end goal?
There are multiple ways to get it
ItemAtIndex node with index of 0, or use a code block with the following:
x[0];
Of course, if I use the x [0] I am calling the list 0 List, but I would like to call the list not by the list number but by the font, how could I call the list 0 using the letter A
Use the IndexOf node, search for A or B or whatever, then use that index on to get the list.
Dynamo is a numeric indexed list program, you will not be able to directly get values by Alpha characters.
I think it does not work as it should?
There is a way although I don’t quite understand why you want to use “A” instead of 0.
Do you need this?
@jw.vanasselt Perfect that is the result that I was hoping to obtain
