Hi everyone,
I want to create a script that change the revision on sheets (instead of changing it sheet by sheet… this is truly pain in the a$$)
I found a Node that let me add a revision to a sheet, but I need to add sheet in that node … can someone help me plz ?!
thx a lot.
Have you looked into Xrev UpRev? I know that allows you to batch update “Revision on Sheet”
https://apps.autodesk.com/RVT/en/Detail/Index?id=5513670845846828779&appLang=en&os=Win32_64
Or not bother with an add-in and use this method: http://archi-lab.net/revisions-on-sheet-w-dynamo/
SeanP
5
Try this, been done several different ways, but this uses Data-Shapes to make it user friendly.
Sheet - Add Revision to Sheets.dyn (24.4 KB)
