Dear professionals,
could you please advise how to get out of a SharedParameterElement class a regular DB Revit Parameter in order use all the properties and method that we can use DB.Parameter class?
what are you trying exactly? is this a Parameter issue ?
like snooping Parameters
clr.AddReference('RevitAPI')
clr.AddReference('System')
iterator = doc.ParameterBindings.ForwardIterator()
data = []
while iterator.MoveNext():
vag = iterator.Key.VariesAcrossGroups
name = iterator.Key.Name
id = iterator.Key.Id
pgs = iterator.Key.ParameterGroup
pts = iterator.Key.ParameterType
uts = iterator.Key.GetSpecTypeId()
isvis = iterator.Key.Visible
total = [name, id, pgs, pts, uts, isvis, vag]
data.append(total)
OUT = data
KR
Andreas
you can use the Guid of SharedParameterElement
here an example
import sys
import System
# Import RevitAPI Classes
elem = UnwrapElement(IN[0])
sharedParameterName = IN[1]
filterName = System.Predicate[System.Object](lambda x : x.Name == sharedParameterName)
sharedParameter = List[Element](
FilteredElementCollector(doc)\
.OfClass(SharedParameterElement)\
.ToElements()).Find(filterName)
if sharedParameter is not None:
elemType = doc.GetElement(elem.GetTypeId())
parameterElem = elemType.get_Parameter(sharedParameter.GuidValue)
OUT = sharedParameter, parameterElem, parameterElem.Definition.Name
Hi Andreas,
This info is exactly what I’m looking for but wanting to get it from a shared parameter element pulled from a family in a directory. Your code will pull the info from a shared parameter bound into the active document.
I’ve got all the code and Dynamo nodes to pull the shared parameter elements from my directory of families as well as the GuidValue from each, BUT… I’m struggling to pull the ParameterType (Data type).
Do you know if this is possible in Revit 2021 API and if so can you give me some guidance?
