Hi all, I was wondering if it is possible to get the scheduled field (parameter name) from the heading?
For example:
Scheduled field = “cooling capacity”
Heading = “total cooling capacity (MBH)”
Can I get the scheduled field “cooling capacity” from the heading “total cooling capacity (MBH)”?
script #1 will get all the scheduled fields from a specified schedule and script #2 will get the heading of all the scheduled fields from a specified schedule. I would appreciate if someone can help me edit script #1 to get the scheduled fields from the heading list from input 1 or for script #2 to get the heading from the scheduled field list from input 1. Thanks
Script #1
import sys
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
# The inputs to this node will be stored as a list in the IN variable
schedule = UnwrapElement(IN[0])
colHeading = IN[1]
# Start the transaction
definition = schedule.Definition
fieldOrder = definition.GetFieldOrder()
paramNames = [definition.GetField(i).GetName() for i in fieldOrder]
# End the transaction
# Assign your output to the OUT variable
OUT = paramNames
Script #2
import sys
# Import RevitAPI
paramNames = IN[1]
colHeadings = [definition.GetField(i).ColumnHeading for i in fieldOrder]
OUT = colHeadings
Why do you need to use the header? Why can’t you get the parameter directly?
My first suggestion would be to get the index of the header you’re looking for and then the item at that index from the list of parameters. (Just make sure no parameters are hidden when getting the index.)
If I remember correctly you can get the information that you’re looking for from the tableview class. That class contains all the information of how a schedule is shown in revit.
