Get rotation of cropped view
Hi
I have some views which have ‘crop view’ assigned. The crop region has been rotated and I’m trying to work out by how much so that I can sync this with a north point.
View direction (from Clockwork) returns I think the view plane - so a floor plan is 0,0,1. I think the parameter i need is ‘UpDirection’ but not sure how to retrieve it.
I though i could modify the Python script within the View.Direction custom node but it is returning different results.
clr.AddReference('RevitAPI')
def ViewDirection(view):
	if hasattr(view, "UpDirection"):
		return view.UpDirection.ToVector()
	else: return None
views = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [ViewDirection(x) for x in views]
else: OUT = ViewDirection(views)
Any suggestions?
Hey @Paul_Wintour,
Python:
#Import the Revit API
view = UnwrapElement(IN[0])
res = view.UpDirection
OUT = res
Thanks @MartinSpence. I modified slightly to take multiple views…
res = []
for v in view:
	res.append(v.UpDirection)
OUT = res
Do you know what time of output it is? It seems to be a string instead of a vector or point. As a hack I’ve used split string but I’m sure there is a better way to handle it within the Python code.
Hey Paul,
Yeah cool :slight_smile:
It outputs a vector. I’ve tried to illustrate it here, where I’ve converted the Revit Vector to a DS vector:
I have manually rotated the crop 30 degrees.
