Hello, is it possible to select via the API the view associated with the cropbox (which has a different ID from the view)
next chart
Can we retrieve it from the view its Id without going through a selection
The rotation is working fine, I searched the View class but I think I need to search another class but I don’t know which one
Python script:
import sys
import math
clr.AddReference('RevitAPI')
#Inputs
Elem_view = UnwrapElement(IN[0])#View
Elem_to_rotate=UnwrapElement(IN[1])# View or BoundingBox or CropBox i don't know
Point_rotate=IN[2].ToRevitType()#Point
angle_rotate=IN[3]*math.pi/180 #Radians
#Preparation work
Line_axis=Line.CreateBound(Point_rotate,XYZ(Point_rotate.X,Point_rotate.Y,Point_rotate.Z+1))
#transaction to do the job
transf=ElementTransformUtils.RotateElement(doc,Elem_to_rotate.Id,Line_axis,angle_rotate)
OUT = transf
thanks in advance
Sincerely
christian.stan
