Get open Revit Windows (UIViews)
Hello Dynamo Friends :slight_smile:
I would like to know if there is a method to get the sheets that are currently open in the project.
Happy about any advice!
Kind regards
Don’t you mean Windows?
If so, not that i know of, but my best bet would be Rhythm.
If not, be more clear.
Edit.
No, Rhythm doesn’t have something you are looking for.
Hi @gerhard.p ,
You can retrieve this in Python with GetOpenUIViews()
OUT = []
uiviews = uidoc.GetOpenUIViews()
for uiview in uiviews:
    OUT.append(doc.GetElement(uiview.ViewId).ToDSType(True))
There’s a core node for the active view, but if you want all open views then I believe you’d have to go the python route.
Amazing! That will improve a lot of my scripts because everytime i want a user to select a sheet i want to list the opened sheets first :slight_smile:
Thanks Dan!
Out of curiosity.
Why do you want that (with Dynamo)?
For placing views on sheets.
I have this script that lets you move or duplicate views to another sheet.
You have to select the target sheet from a dropdown of 100-200 sheets.
Usually we have this sheets already open, so i want to put the open sheets on first place of the list of sheets for the dropdown.
I had to change the code to make it work in Revit 2022 @Daan, had to remove ToDSType:
import System
OUT = []
    OUT.append(doc.GetElement(uiview.ViewId))
Here is the graph for adding the open sheets to the start of my sheet list:
Bonus question, would it also be possible to get the open windows of all open documents, not just from the active document?
Don´t know a use for that now, but maybe in the future…
documents = uiapp.Application.Documents
I found an interesting “issue” when getting open windows, or in my case when i want to get open sheets.
If a sheet is open and a view is active on the sheet, the python code will get the view and not the sheet.
Thats a problem for me because i can´t tell if a view is opened as a window or if a view is active on a sheet.
Here you can see i get a view insted of the second sheet:
