Get Insulation on Pipe
Hi Everyone,
I would like get Insulation on Pipe. Can you suggest me an Idea.
Many Thanks,
Hey
Can you show what you have tried so far and where you are getting stuck? Should be able to help out from there
I have a pipe with Insulation. I would like to get Insulation of pipe when i select pipe. Yah!
Thanks for your help
I meant can you show what you have tried in Dynamo so far? Upload your script and where you are having trouble and we can help out
This is a bit tricky as there is no out of the box way to get the pipe insulations for a pipe, you need access to the Revit API.
You can use the code below to access the insulation of a pipe:
clr.AddReference("RevitAPI")
if isinstance(IN[0], list):
	pipes = UnwrapElement(IN[0])
	pipes = [UnwrapElement(IN[0])]
listout = []
for pipe in pipes:
	try:
		insulation = InsulationLiningBase.GetInsulationIds(doc,pipe.Id)
		listout.append(doc.GetElement(insulation[0]))
	except:
		listout.append(None)
OUT = listout
I’ve also added the node to my package MEPover
Great tricky !!! Best thanks T_Pover
You can get parameter value by name “Insulation Thickness” and also get “Insulation Type” from the Pipes
