Get file path of non-system families?
Hi guys,
did anybody already write a node to get the file path of the family, where it is located on the server?
The path I would see if I reload a family.
Ideas welcome!
Thorsten
It seems to be possible programatically
http://adndevblog.typepad.com/aec/2012/09/accessing-the-path-a-revit-family-document-from-the-family-instance.html
But you have to pretend to edit the family, then back out of it. Not sure if that is possible in Dynamo.
As far as model management/auditing, this would be a great tool- find all those rogue families…
Andrew
I came across this thread searching for the same functionality and made a rough implementation in Python that accepts a list of families: https://bitbucket.org/snippets/thomascorrie/qKLEG
clr.AddReference(‘RevitAPI’)
#Close all transactions
trans = TransactionManager.Instance
trans.ForceCloseTransaction()
dataEnteringNode = IN
fam = IN[0]
family = []
path = []
for f in fam:
family.append(UnwrapElement(f))
for f in family:
famDoc = doc.EditFamily(f)
if not famDoc.PathName:
path.append(“Family location not found”)
path.append(famDoc.PathName)
famDoc.Close(False)
OUT = path
