Get family from SpaceTag
how get Get the family from SpaceTag in python?:
Screenshot_8
Hi @til.shviger,
I inadvertently did something similar in this post I literally just posted.
Change parameter of elements into family
You want to use the Element.GetType (py) node and Family.FamilyType node I think.
Cheers,
Dan
this exactly what i need !
but i have trouble at this step
Yup, you don’t need the whole script. just 2 nodes. I have attached what you need…
GetFamilyFromTags.dyn (4.8 KB)
Cheers,
Dan
i need all script because of -Change parameter of elements into family -its my need. change font in spacetags
my be i must choose them
You could do something like this…
done, but font of space tag is not changed
I’m not sure what that says i’m afraid. an error is being caught, but I’ll need a translation from you
sorry
im must be write name of parameter in russian )))
Yes, this is what it will probably be. It is a problem of getting parameters by string rather than the built-in parameter. I will fix this, but you can write it in russian and should work (i think)
your script is worked !
excellent work!
thanks you very much!
Thanks @til.shviger, but I can’t take credit for this. That node at the end was 99% @DENIS.REMESNIK. :slight_smile:
but your 1 % its main decision for the end code,
soo,
we are all may dance now
dance
Ha, if only I could dance, when I do it’s usually posted on FB and then crimewatch.
:laughing::sunglasses:
Russion code and USA code
its looks like:
russion hare
plus USA terminator
____________________ +____________________________
терминатор
and we get this universal soldier
_______________________ =___________________________
заяц
Hi @til.shviger,
I have updated the code in the other thread, this should now not care if you’re from USA or Russia and be just plain Robot.
Cheers,
Dan
Ok,
I’ll look this with joy,
thanks, Daniel )
