Hi ,
With “FamilyInstance.Sapce” and “Element.Name+” I can extract space name and number from “All Elements of Category” and so push information in parameter in family.
But Python return only one string = Space Name and Space number
How can I separate in two to write two parameters one for Name and one for Number ?
daniel OLIVES
French user - LYON
Hello. Can you post a picture of what you get from the python?
The python is in CLOCKWORK ELEMENT.Name+ node.
Daniel
Can you take a picture in Dynamo of the output of that node?
This area after running the script.
Hi Kennyb6,
Space Name in green and space number in red
Daniel
WSP_02_Copie_EspaceNom_EspaceNumero2Parameter_AllCat_V2.dyn (24.8 KB)
I find how to put image and file
Daniel
Hi Kenny,
Thank’s for your help.
I just need that architec name room without space in name or without space in number code
I specify this to him.
Tan’s
Daniel
If you don’t want the space in the number code, use this in the code block:
[x[0], x[1]+x[2]];
Note that you will have problems with the nulls in your output of Element.Name+. You should filter them out before doing this.
