Get Exterior Faces Of Walls From Linked File
Hi, guys I ran into the issue with HostObjectUtils.GetSideFaces, it’s works well if element is not linked as you can see in picture below
clr.AddReference('RevitAPI')
surfaces = []
walls = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
for wall in walls:
    side_face = HostObjectUtils.GetSideFaces(wall, ShellLayerType.Exterior)[0]
    surface = wall.GetGeometryObjectFromReference(side_face).ToProtoType()[0]
    surfaces.append(surface)
OUT = surfaces
But when I tried to feed linked wall elements the error is raising. Do you have any suggestions or where I can learn how to avoid that error? Thank you all in advance
That’s snippet of code below to obtain walls from link
clr.AddReference("RevitAPI")
import System
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
links = FilteredElementCollector(doc).OfClass(RevitLinkInstance)
link_docs = [link.GetLinkDocument() for link in links]
category = IN[0]
error_reports = []
result = []
for link_doc in link_docs:
    try:
    	errorReport = None
    	result += FilteredElementCollector(link_doc).OfClass(Wall)
    except:
    	import traceback
    	error_report = traceback.format_exc()
    	error_reports.append(error_report)
if len(error_reports) == 0:
	OUT = result
	OUT = error_reports
And after code pretty much the same with the exception of input for walls
walls = IN[0]
surfaces = []
for wall in walls:
OUT = surfaces
Not at the PC to check, but I recall that as the walls aren’t in the document they aren’t actually wall objects in the API, but instead LinkElement objects. If you merge the two Python blocks into one I believe you should be able to progress as intended though as you’re collecting wall elements in the ‘get walls from link’ Python.
another way maybe could be genius loci compound surface reference…it give you the surfaces exterior/interiør as well and should work on link
you need to Unwrap the input elements to expose them to the Revit API
walls = UnwrapElement(IN[0])
Thank you so much, it worked :sunglasses:
