Get Elements of Valve connected to
Dear Dynamo team,
Is is possible with Dynamo to get the Pipe elements of Valve connected to?
For example: output should be 2 pipe element if valve connected to 2 pipes (in and out).
There’s a node called ‘MEP fitting connected curves’ in the ‘MEPover’ package that should be able to do what you want.
Thanks T_Pover. Worked Great.
