Hi all,
I need to get the element id of the pipes which are connected to a particular fitting. Is there any way to get this by using dynamo?
Hi all,
mepover
Hi @Akhilthanku
this just one of any way:
for all pipes and fittings IN ACTIVEVIEW you can get list of pipes and connect to them fittings
for example
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import*
doc=DocumentManager.Instance.CurrentDBDocument
collector=FilteredElementCollector(doc,doc.ActiveView.Id)
ps=collector.OfCategory(BuiltInCategory.OST_PipeCurves).WhereElementIsNotElementType().ToElements()
ft=collector.OfCategory(BuiltInCategory.OST_PipeFitting).WhereElementIsNotElementType().ToElements()
ft_=[]
for i in ft:
try:
i.MEPModel.ConnectorManager.Connectors
ft_.append(i)
except: pass
ps_ft_connect=[ [i,j] for i in ps for j in ft_ for x in i.ConnectorManager.Connectors for y in j.MEPModel.ConnectorManager.Connectors if x.IsConnectedTo(y)==True ]
dict= dict()
for x in ps_ft_connect:
i = x[0]
if i in dict:
dict[i].append(x[1])
dict[i] = [x[1]]
result = sorted([[k,v] for k,v in dict.items()], key = lambda x: x[0])
for x in result:
for y in x[1]:
x.append(y)
x.remove(x[1])
OUT = result
You are may check to correctly work this script that:
And
for all pipes and fittings you can get list of fittings and connect to them pipes
then just change this string:
to this:
ps_ft_connect=[ [j,i] for i in ps for j in ft_ for x in i.ConnectorManager.Connectors for y in j.MEPModel.ConnectorManager.Connectors if x.IsConnectedTo(y)==True ]
Hi @Akhilthanku Try using the MEPOver node:
Or try this one from MEPover:
the easiest way was under the nose
ya thanks everyone. I used MEPover
hello,
Anyone knows a way i could possibly host pipes to a surface?
