HI
I’m getting crazy searching for a possibility to get only the elements wich are inside of a viewport.
Please help???
HI
Please help???
try All elements in View
I tried:
-Elements by View
-Nodes from bimorph with bounding box
They did not work, i get only Null Lists
Regards
can you show me the graph?
this one might help
is your graph running on automatic or manual?
also, take small steps, test with just one view at a time
Manual and i tried also with just one view
Revit 18 and 19.
Dynamo 2.02
are these the only two node you have in the graph or is this just a part of a larger graph?
In this graph are more things, but i tried it in a new one just with this two nodes and it doesn’t work either.
i’m out of new ideas here exept for trying list@level
It seems to be only with Revit 2018.
In 2019 it works… I will try some more things…
