Get Elements In View(s)
Hello Dynamo Community,
I’m encountering an issue while trying to filter families within a view using Dynamo. Here’s the problem I’m facing:
Problem Statement:
I’m working on a project where I need to retrieve families that are visible in a specific view. However, the current script I’m using also retrieves subfamilies that are created within the main/global family. What I actually need is to retrieve only the master family that contains all the subfamilies within it, excluding the subfamilies themselves.
Current Approach:
I’ve attempted to filter the families within the view using Dynamo scripting. However, the script I’m using seems to be returning not only the master families but also the subfamilies created within them.
Look at “FamilyInstances.SubComponents” from archilab or “Element.SubComponents” from Clockwork. Use that to get the subcomponents of all the elements and use those results to filter out all matching elements in the main list.
an example with API
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
toList = lambda x : x if hasattr(x, '__iter__') else [x]
views = toList(UnwrapElement(IN[0]))
out = []
for v in views:
    elems = FilteredElementCollector(doc, v.Id).OfClass(DB.FamilyInstance).Where(lambda x : x.SuperComponent is None).ToList()
    out.append(elems)
OUT = out
Hi @c.poupin ,
Thanks for your input! I’ve tested the code, and it indeed works well. However, I found that adding some additional filters could enhance the results.
