How to get the family without the nested familys?
Hi all,
I try take make a script that remove the Duplicate Items at the same position.
The script is almost ready but I have a little issue:
The node “all elements of category” takes all the familys include the nested family.
Is there a way to take only “primair family” without the nested family below?
KG,
Jan Willem
Hi @jw.vanasselt,
You can use the SuperComponent node from Clockwork for this:
It will return null, if the element is a parent family. So run it through this, and use the output to isolate your parent families from your original list :slight_smile:
Hi Martin,
Thanks alot!
Can you share the python script?
Yeah no probs :slight_smile:
#Import the Revit API
clr.AddReference('RevitAPI')
#---###Start scripting here:###---#
elems = UnwrapElement(IN[0])
OUT = []
for i in elems:
	super = i.SuperComponent
	if super == None:
		OUT.append(i)
		OUT.append('This is a SubComponent')
Thanks :slight_smile:
How do I adapt the script in a way that the only output constist of a list of the SuperComponents and not the strings with ‘This is a SubComponent’?
Found it! Still learning Python :sweat_smile:
OUT = []
for i in elems:
	if super == None:
		OUT.append(i)
		pass
