Get curtain panels conectors
Hello.
Im trying to get the boundary of conector piece between panels for fabrication in plywood.
For now i just can get lines on each panel with the right direction and angle.
I tried to join the lines that makes the conector piece with no sucess.
In the example I got surfaces from lines to mimic the piece geometry (the idea is to get the perimeter curves of the piece that conect surfaces with common edges)
Thank you for your help
Prueba.dyn (12.4 KB)
Prueba.rfa (448 KB)
