I want to check if rebar is slolid in view and set is as solid.Check Spacing.dyn (20.1 KB)
Clash Detection 2.0.dyn (65.4 KB)
you might want to use another Collector constructor “FilteredElementCollector(doc, doc.ActiveView.Id)”
http://www.revitapidocs.com/2018.1/6359776d-915e-f8a2-4147-b31024671ee1.htm
this is the ouput im getting from it
could you post another screenshot of your modified script? Why you iterate through the collector instead of rebarElements?
line 37, your collector(currview) is not in used.
line 48, lower-case, View instead of VIew.
i finally got the view…
using uidoc.activeview
now to check if the rebar is solid in view…im doing it wrong
showing all rebars are solid…but they arnt…
how is it look like if it is solid
like extruded cylinders, i managed to complete the Script to change it to solid,
But when getting the current state its always giving me wrong parameters.
