something wierd is going on with the “Get Cogo Point Groups Node”. When in automatic mode, the node does not require the “document.current” node to generate an output. It will then display, later, it will display an error. It seems buggy.
Hi @ddrennen2QDK2,
I can reproduce the behavior in automatic mode, so we’ll investigate further. However, I cannot reproduce the issue when trying to retrieve COGO points. It works correctly in all my tests. Are you able to share a dataset?
sent via email…
