CogoPointGroup.CogoPoint does not work in civil3d Dynamo
the CogoPointGroup.CogoPoint node in Civil3d 25/ Dynamo 3.0.0.1327 does not return the COGO points from a selected point group. The point group is recognized, but the output is empty!
Hi @y.srewil ,
Could you drop the relevant DWG file. Everything is working as expected(See below Screenshot). DWG file will allow others who are trying to help you to better understand the issue and provide more accurate solution.
Hallo Kulkul,
Thanks for the response!
I restarted my computer, and the issue suddenly disappeared. The node is now working perfectly and returning the COGO points exactly as expected. I’m not sure why this happened, but since everything is resolved, I have marked this issue as closed.
