Get Bearing of 2D Line using Dynamo
I am trying to create a family that will report the bearing of a 2D line. Has anyone done anything similar to this using Dynamo?
Hi
Not sure what you want to achieve?
Is this what you want?
Thanks Patrick
Yes, that is close just need to change the units to deg/min/sec.
Here is an example of what I am trying to achieve that I have done manually.
This graph can help you to get the output but then you need to combine them in to decimaldegrees,minutes,seconds
Hi @_Bruce Wondering if you figured this out as I’m looking for the same now. thanks
