Get and Set parameters of a Linked File
It’s probably better to unload and reload the link to make it work for non-workshard files as well.
# Code by Einar Raknes, 2017
# Import List ( ICollection(ElementId) = List[ElementId]() )
clr.AddReference('System')
# Import Revit API
uidoc = DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
app = DocumentManager.Instance.CurrentUIApplication.Application
link = UnwrapElement(IN[0])
comment = IN[1]
linkPath = link.GetLinkDocument().PathName
linkType = doc.GetElement(link.GetTypeId())
linkType.Unload(None)
linkDoc = app.OpenDocumentFile(linkPath)
el = FilteredElementCollector(linkDoc).OfCategory(BuiltInCategory.OST_Site).WhereElementIsNotElementType().ToElements()[0]
TransactionManager.Instance.EnsureInTransaction(linkDoc)
el.get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS).Set(comment);
linkDoc.Close()
linkType.Reload()
Without linkType.Unload() I get the message mentioned above:
