hi everyone,
i want to know how can i a get and set dynamicpropertybynam in python , i dont want by node but in python if it possible ?
see this
/// https://forums.autodesk.com/t5/net/dynamic-block-properties-not-being-updated-using-c-net/m-p/10559162
private static void DisplayDynBlockProperties( Editor ed, BlockReference br, string name )
// Only continue is we have a valid dynamic block
if (br != null && br.IsDynamicBlock)
ed.WriteMessage( "\nDynamic properties for \"{0}\"\n", name );
// Get the dynamic block's property collection
DynamicBlockReferencePropertyCollection pc = br.DynamicBlockReferencePropertyCollection;
// Loop through, getting the info for each property
foreach (DynamicBlockReferenceProperty prop in pc)
// Start with the property name, type and description
ed.WriteMessage( "\nProperty: \"{0}\" : {1}", prop.PropertyName, prop.UnitsType );
if (prop.Description != "")
ed.WriteMessage( "\n Description: {0}", prop.Description );
// Is it read-only?
if (prop.ReadOnly)
ed.WriteMessage(" (Read Only)");
else if (!prop.ReadOnly)
ed.WriteMessage(" (READ WRITE Only)");
//Switch Property
if (prop.PropertyName == "STEM_LENGTH" )
object[] values = prop.GetAllowedValues();
prop.Value = 48;
// GETTING THE EXCEPTION HERE.
thk
