Get (and ideally set) DWG/DXF Export settings layer modifiers
Hi all,
I’m trying to verify, and ideally automatically fill-in missing DWG/DXF Settings layer modifier settings after having imported these from another Revit file using Transfer Project Settings.
What we found is that if our other Revit file, e.g. a template, doesn’t have all the layers which are present in the file which we insert the DWG/DXF settings to, some layer modifiers which we use are not included.
I found this topic from 2018 which allows to read information from the layers tab of the DWG/DXF Settings tab and I’ve been able to extend that further, but I’m not sure how to extract information from the Autodesk.Revit.DB.LayerModifier values it gives me.
clr.AddReference('RevitAPI')
settings = IN[0]
if not isinstance(settings, list):
    settings = [settings]
def getExportInfo(set):
    layername = []
    layermodifiers = []  # List for layer modifiers
    cutlayermodifiers = []  # List for cut layer modifiers
    options = set.GetDWGExportOptions()
    table = options.GetExportLayerTable()
    keys = table.GetKeys()
    layerinfo = table.GetValues()
    for i in layerinfo:
        layername.append(i.LayerName)
        # Retrieve layer modifiers and cut layer modifiers
        layermodifiers_list = i.GetLayerModifiers()
        cutlayermodifiers_list = i.GetCutLayerModifiers()
        layermodifiers.append(layermodifiers_list)
        cutlayermodifiers.append(cutlayermodifiers_list)
    return zip(layername, layermodifiers, cutlayermodifiers)
exportSettings = [getExportInfo(UnwrapElement(i)) for i in settings]
OUT = exportSettings
Revit API Docs: GetLayerModifiers Method & GetCut LayerModifiers Method
2025-01-19 Extract DWG-DXF Settings layermodifer information.dyn (11.7 KB)
Ideally, for all layers where applicable/possible I would like to set the layer modifier as {Phase_Created)_{Phase_Demolished} programmatically.
