Choose export settings revit to dwg
Hey guys,
I’m working on a project which is to have a dynamo which is able to convert all my desired sheets from revit to autocad, for that I took 2 different dynamo, first one is to select sheets ( left part ) and the other part made by Konrad which exports the selected sheets in dwg.
Everything works perfectly fine except that the dwg I have is in IndexColor meaning everything is in Pink making it worthless.
Does any one of you know how to add a command in the code to change the settings of export from IndexColor to TrueColor ? Or else maybe to select a predefined export setup ?
(I tried a lot of things in the command with “ExportColorMode.TrueColor” or “SetDWGExportOptions()” but nothing worked out)
Hope my English wasn’t too bad, French student here.
Thank you for your time
Vincent
Here is the screen of Dynamo and code below
Here is the code
# Copyright(c) 2016, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
def ProcessList(_func, _list):
    return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ProcessParallelLists(_func, *lists):
	return map( lambda *xs: ProcessParallelLists(_func, *xs) if all(type(x) is list for x in xs) else _func(*xs), *lists )
def Unwrap(item):
	return UnwrapElement(item)
folderPath = IN[0]
if isinstance(IN[1], list):
	views = ProcessList(Unwrap, IN[1])
	views = list(Unwrap(IN[1]))
if isinstance(IN[2], list):
	names = IN[2]
	names = list(IN[2])
RunIt = IN[4]
def ExportDwg(name, view, folder = folderPath):
	options = DWGExportOptions()
	options.MergedViews = IN[3]
	views = List[ElementId]()
	views.Add(view.Id)
	result = doc.Export(folder, name, views, options)
	return result
if RunIt:
	try:
		errorReport = None
		# run export
		ProcessParallelLists(ExportDwg, names, views)
	except:
		# if error accurs anywhere in the process catch it
		import traceback
		errorReport = traceback.format_exc()
	errorReport = "Please set the RunIt to True!"
#Assign your output to the OUT variable
if errorReport == None:
	OUT = 0
	OUT = errorReport
# Import RevitAPI
import System
import sys
def Unwrap(item):
folderPath = IN[0]
	names = IN[2]
	names = list(IN[2])
RunIt = IN[4]
	options.Colors = options.Colors.TrueColor
	views.Add(view.Id)
	return result
if RunIt:
	try:
		errorReport = None
		# run export
	except:
		import traceback
	OUT = 0
	OUT = errorReport
Hi Tomasz,
Thanks for your reply, it actually worked, thing is, now when I export through Dynamo, Dynamo takes the “in-session export settings” with TrueColor and not My settings that I have configured before which creates some ugly stuff once in autocad.
Basically i tried something like this but the code doesn’t respond at all.
	options.Select_Export_Setup = Export_HVAC
	views.Add(view.Id)
	return result
Vincent
Dont have time to try this in revit/dynamo, but it should be sth like this:
SetDWGExportOptions(options.GetPredefinedOptions(doc,“dwg_export_template_name_as_string”))
Tomasz,
Thanks for your reply again, and sorry to bother you once again, maybe I get it wrong but when i add your line code to my script it does nothing :
I switched :
to:
SetDWGExportOptions(options.GetPredefinedOptions(doc,Export_HVAC))
# Import RevitAPI
import System
import sys
def Unwrap(item):
folderPath = IN[0]
	names = IN[2]
	names = list(IN[2])
RunIt = IN[4]
	# '1' = dwg export settings name
	options = options.GetPredefinedOptions(doc,'1')
	views.Add(view.Id)
	return result
if RunIt:
	try:
		errorReport = None
		# run export
	except:
		import traceback
	OUT = 0
	OUT = errorReport
It’s all working, thank you so much Tomasz !
Happy year-end festivities,
Bbye
Vincent
Glad to help,
pls mark it as solution :slight_smile:
It’s possible to extract the predefined export setup as a IN variable?
I try differents solutions but my python it’s so bad.
Your script seems correct.
GetPredefinedOptions(doc, IN[5]) works for me.
options = options.GetPredefinedOptions(doc, IN[5])
Are you sure that the problem doesn’t result from your sheets or views inputs ?
Thank’s Alban
i use the sheet input for export but not work for me.
