Is there a way to get a sample line group without creating a new one? The current Sample Line Group Node is only able to create a new group, but I need to add new sample lines to an existing group.
I tried the Camber Sample Line Group node, but the Create Sample Lines node doesn’t recognize Camber objects. (Is there a way to convert a Camber object back to a normal object?)
Thanks! Sorry for the pedestrian question. I was focusing on the Sample Lines category instead of the Alignment category. I need to think of Sample Line Groups as “above” Sample Lines themselves, and more correctly “under” Alignments.
No worries at all! If you weren’t able to find it, then it means that it wasn’t very intuitive, which is not your fault ![]()
Library organization is a challenging topic. What is intuitive for some is not intuitive for others, so we try to find a line down the middle somewhere ![]()
