Get All Sections
Hi All,
I have been trying to collect all sections in a project. I am using python Filtered Element Collector and of class(ViewSection). I am able to collect all view sections which include callouts, elevations, axonometric views and sections. I have been facing an error as
**"Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. **
unexpected token ‘=’".
Below snaps are sample images and code.
Method 1:
clr.AddReference(‘RevitAPI’)
ViewSections = FilteredElementCollector(doc).OfClass(ViewSection).ToElements()
vs_str = [ ]
for v in ViewSections:
if v.ViewType.ToString = “Section”
vs_str.append(v)
OUT = vs_str
Method 2:
vs_str = [ ]
if v.ViewType = Section
vs_str.append(v)
OUT = vs_str
@jagadeesh116 ,
i come to here
import System
clr.AddReference('RevitAPI')
clr.AddReference('System')
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views)
sections = collector.WhereElementIsNotElementType().ToElements()
OUT = sections
Hi Draxl,
the above script gives null out put .if we use another line as
views =
for v in sections:
views.append(v.Name)
gives view names which include floor plans,celing plan and sections.I am trying to seperate sections.
@jagadeesh116 ,
thats realy weard… i can`t get it.
sections.dyn (11.9 KB)
This is what’s causing your problem. A single = means “to set equal to”. A double == means “is equal to”. The former changes a value and the latter checks a value.
@Nick_Boyts ,
grafik
i got this warning …
You’re not iterating through your list. You’re trying to get the ViewType from the list instead of the view right now.
Hi Nick,
Thanks for ur response.
Actually there is typing mistake i have given ==(“=” means assign values,"==’ means equals).
As per ur next reply i have understood and tried:
get sectionlines in active view
Views = FilteredElementCollector(doc).OfClass(View).ToElements()
get viewname parameter
ViewT =
for v in Views:
if v.ViewType.ToString() == “Section”:
ViewT.append(v.Name)
OUT = ViewT
I got the result thanks
