How do i get the pipe fittings of type “elbow” ?
I looked inside the familys but it seems that the parameter “Type Part” wich classifies the fittings in elbows, cross, tees… is not available. Is there a way to do so?
Thank you!
Couldn’t find any node in that package to do thar…
However, i’ve seen a lot of really nice nodes in this package.
Hey,
use a group tool, do you have anything already started? its could be a built in parameter.
Is there a way to make this node work for a linked file?
i Think this node solves my problem… however it returns null for linked pipe fittings
Edit: I tryed this, and it did not work
Tryed that in dynamo 1.3.3 and 2.0.1… It didn’t work in both Versions
@T_Pover Could you please share the code that is behind the node Mechanical Fitting info.
This is what i got.
Thank you Kulkul!
