Get all categories to which shared parameter is assigned
Hello Dear professionals,
Could you advise a good way how to get all categories that are associated with shared parameters.
I already checked one topic:
it does not work. Have no idea why.
error :
I need to know which Shared parameters I can delete based on categories list which I expect to get with Dynamo
@m.shcheblykin ,
i can you just give you hint… i stuck after getting the shared parameters…
GetCategoriesOfSharedParameters.dyn (13.7 KB)
clr.AddReference('RevitAPI')
clr.AddReference('System')
params = IN[0]
shared = []
for i in params:
    shared.append(i.IsShared)
OUT = shared
KR
Andreas
You could use the Get Shared Parameter node from the Genius Loci package.
hello,
thank you for your reply.
The point is that I do not have shared parameters file and only God knows from how many shared parameters file (txt) I got 1600+ shared parameters in the model. I need to find the categories directly from the revit model
