I am trying to grab all 2D items in a list of views.
I have this… but it’s going to be a long list?
Is there a better way rather than listing each type by name?
Here’s how I would start to go about it:
How do I check if it’s an annotation?
You might also be able to just check for an OwnerView. That should cover annotations and just leave certain detail components to check.
hello, elements without volume, maybe a track
Cordially
christian.stan
Once you have the category, pull the category type from that. There are five possible values per this enumerator: https://www.revitapidocs.com/2023/eb96f224-a134-50e6-57e8-32bcb13bee7d.htm
Give it a shot and see where you get. ![]()
Do you have anything listed as an annotation from the category type node?
Nope
i made one time boundingBoxes and all 2D Elements had a hight by 0.000…
KR
Andreas
This is the best approach in my experience, very quick query to make.
I use this exact property in this example code here for pyRevit (mostly works the same way in Dynamo aside from the imports and references to DB not being needed) to filter selection down to 2D elements:
Not had a chance to see if this is what i’m after yet…
Dragged on to 1000000 other things ![]()
