Geometry surface subtractions
Hi, I am trying to subtract a circle representing a drainage channel from another surface, however, I cannot seem to do it with surfaces.
I was thinking along the lines of boolean difference in grasshopper. Is there a simple way of generating the surface with the semi circular recess. Definition attached.
Cill_beam_type_2.dyn (24.4 KB)
Convert your cutting surface to a solid and use Surface.SubtractFrom.
Thanks Nick, I was thinking along that line.
