This may appear a repeat I followed a couple of threads although none of the responses appear to have resolved the issue. points appear to be in the same plane ie. Z =0
ie. Flatten before and after geometry.intersection
Definition attached, aim of the which is to generate a orthogonal grillage for a skew greater than 25 degrees.
I am running DynamoDS 1.1.0.2093 evaluation, (same issue with 1.2.2 in the office)
Geometry.intersect and Geometry.intersectall
Workflow
Determine extents of deck geometry shew greater than 25degrees
Use extents to generate parametric grillage lines/curves
Three sections require to capture different line divisions ie. triagular lead and trailing sections with the central rectangular sect
Generate lines longitudinal and transverse (efficiently eventually)
Generate intersections and capture points…vertices ?
Sort points according to Euclidean geometry ie. x then y then z
Capture and sort the points in 6 branch data trees due to 6 longitudinal lines/curves
Re-draw lines longitudinal and transverse
My cunning plan has become unstuck at the Geoimetry points intersections.
I did follow a thread but it was unresolved.Surface_Bridge_Rev_C.dyn (91.4 KB)
rgds
Kenyon
