Geometry Intersect All in python
@Vladimir For two lists (like in your example) with equal length @L3, you can do something with zip() like this:
Note: You will have to tweak the logic to account for lacing if the count @L3 is not going to remain same in both lists AND/OR if the surfaces in IN[1] is going to increase @L2
clr.AddReference('DSCoreNodes')
from DSCore import *
Curves = IN[0]
Surfaces = IN[1]
Ptse= []
for curves,surface in zip(Curves,Surfaces):
	temp = []
	for c in curves:
		Ptsg= Geometry.IntersectAll(c,surface)
		temp.append(Ptsg)
	Ptse.append(temp)
OUT = Ptse
