I’m looking for a python code that would do the same as geometry.intersect.
In my case, I would like to intersect two lists of solids with the same number of elements.
I just need to compare the element A (0) with B (0), then A (1) with B (1) … etc
Hello, please send what you found so far on this topic…
You can check out this node from Bakery: https://dynamonodes.com/2016/07/13/revit-element-clash-detection-v1/
I tried to change the Clash Detection V1 node, but I have only empty single list.
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
#dataEnteringNode = IN
clashElementsAdirty=IN[0]
clashElementsBdirty=IN[1]
# Start Transaction
clashElementsA = []
clashElementsB = []
clashGeomA = []
FailuresA = []
clashGeomB = []
FailuresB = []
clashFoundA = []
clashFoundB = []
clashSolids = []
clashPoints = []
#clashGeomA=IN[0]
#clashGeomB=IN[1]
for a in clashElementsAdirty:
try:
# clashGeomA.append(a.Geometry()[0])
clashGeomA.append(a)
clashElementsA.append(a)
except:
FailuresA.append(a)
for b in clashElementsBdirty:
try:
# clashGeomB.append(b.Geometry()[0])
clashGeomB.append(b)
clashElementsB.append(b)
except:
FailuresB.append(b)
counterA = range(len(clashElementsA))
counterB = range(len(clashElementsB))
for i in counterA:
tempGeomA = clashGeomA[i]
if clashGeomA[i].DoesIntersect(clashGeomB[i]) == True:
clashFoundA.append(clashElementsA[i])
clashFoundB.append(clashElementsB[i])
tempSolid = clashGeomA[i].Intersect(clashGeomB[i])
clashSolids.append(tempSolid[0])
clashPoints.append(tempSolid[0].Centroid())
# End Transaction
OUT = clashFoundA, clashFoundB, clashSolids, clashPoints, FailuresA, FailuresB
Hi
Yes, but the problem is that it will process all combinations of 2 lists.
For a list of 100 items this represents 10,000 combinations.
But in my case I have 2 lists or each item of a list already corresponds to the second list.
It is necessary to compare A (0) with B (0), then A (1) with B (1).
Actually, it doesn’t seem to process all combinations in my case…
If, looking at the original code of the Clash Detection V1 node, there are 2 nested loops.
Ok I think I have found it.
Shift to the left of “If”
