I’m experimenting with code kindly given to me by @sovitek, however when testing on some models I am met with the ‘dereferencing a non-pointer’ error. I know this normally occurs when a node is fed an unexpected null value, however I don’t have a great enough understanding of how the previous node, imported from the Ampersand package, works.
If anyone could either point me in the direction of some documentation so I can better understand how the closed loops from curves node works, or provide me some guidance on the issue I would be grateful.
I think the issue may be coming from the fact that there are overlaps once the walls are extended, due to a curtain wall grid around the outside of the building, but I am not sure. Here is an image of the walls of one building for reference.
