I wrote a graph to lock the centre of columns to the centre of a wall.
Using the GeniusLoci package what happens with the columns is that the references are shown all on one level. While the wall references are in the correct location. So when I push those nodes into the Lock ByReferences, it doesn’t work. any advice would be helpful.
I don’t think your going to be able to do that unless you use something like a reference plane that you lock to the walls first, then lock the column. Or better yet use grids to set up the layout.
It does work since a wall and column family have reference planes in the family, in order to have the Lock ByReferences work, the reference planes need to be overlapped with each other. Using Grids is out of the question.
The graph’s purpose is to lock columns to the wall they reside within, so in the event of a wall moving the columns move with the wall.
The Lock Byreferences node from Genius Loci only works if the references overlap each other, if they don’t it returns as a null. but the references for the columns are shown on the wrong level which I can’t figure out why…
