Generative Design - weird things happening
So I wrote a script (can’t share as it’s a work thing)
It was all working and running beautifully in the GD too… Then I added some stuff and poof it starts being weird.
The thing that’s causing the issue (I think) is that I’ve run something though two filters in a row.
If I delete the second filter it’s fine.
I can’t combine the filters as item 1 only wants filters abc and item 2 wants filters ab… So I have to keep filter c apart.
In Dynamo it still displays fine and gives me the right outputs but in the GD it doesn’t.
I’ve tried rejigging how it filters - I’ve filtered item 1 and 2 with filters a+b and then added filter c for item 1.
I’ve filtered item 1 with filters a+b and then item 2 with all the filters.
I’ve asked it nicely…
Dynamo looks like this:
GD looks like this:
And also seems to be stopping here
Also the “open in Dynamo” button isn’t working.
I’m in Revit 2021.1 and Dyno 2.6.1
Any suggestions?
So after loads more ARGH WTF… I found the actual issue…
It wasn’t the filters.
All I needed to do was go from this:
to this:
As usual the issue was between the keyboard and the chair :laughing:
