Thanks a lot Nick
Hi Nick,
I’m using Dynamo 2.0.3. It has nodes to CreateSharedParameters and CreateProjectParameters. But I can’t use those created parameters in Key schedule. Is there any similar node to Bulk Create Key Schedule parameters instead of Editing field and creating a parameter? That process is a bit too long and I’m trying to create 10 -20 columns per Key Schedule. Please let me know if you know of any solution
Thanks,
Bishesh
You should be able to use project parameters in a key schedule. You just can’t use the same parameter in multiple key schedules.
The project parameters that I created using CreateProjectParameter node are not showing up while creating key schedules. I started a thread with this problem at Bulk Add parameters in Key Schedules
Please let me know if I’m doing something wrong or if there are any additional steps I need.
