I’m trying to extract a combination of two elements in a list that are sequencing.
I have create my list for a test and used code-block script testing with different numbers and it does work, but when I put the same code inside a Function definition code-block I get something I cannot understand. I have also tried with a Function definition that use a cycle for (the same result I got white a “while” loop). Any idea why I’m getting these null lists?
The final aim of the exercise is to get elements (points) two by two from several paths divided in “n” elements so that I could use an adaptive component to create a mesh.
coupleofelements.dyn (16.5 KB)
